[postgis-devel] [PostGIS] #1191: move PREPARED_GEOM define in postgis_config.h
PostGIS trac at osgeo.org
Wed Sep 21 19:30:14 PDT 2011
  Reporter:  strk         |       Owner:  pramsey
      Type:  enhancement  |      Status:  closed
  Priority:  medium       |   Milestone:  PostGIS 2.0.0
 Component:  postgis      |     Version:  trunk
Resolution:  fixed        |    Keywords:
Changes (by robe):
  * status:  reopened => closed
  * resolution:  => fixed
Comment:
 disregard. For some reason I had enable-debug on my 9.1 configure.  My 9.0
 was fine.
 I suspect gremlins are changing my scripts since I don't recall changing
 my build script in past couple of days and certainly not adding in an
 enable-debug.
 Though I thought we stripped notices from our regress tests results.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1191#comment:4>
