[postgis-devel] [PostGIS] #1707: Regress on topology running make check - r9529
PostGIS trac at osgeo.org
Thu Apr 5 06:56:45 PDT 2012
 Reporter:  sindile   |       Owner:  strk
     Type:  defect    |      Status:  assigned
 Priority:  medium    |   Milestone:  PostGIS 2.0.1
Component:  topology  |     Version:  2.0.x
 Keywords:            |
Comment(by strk):
 select setting,boot_val,reset_val from pg_settings where name =
 'search_path';
 select topology.AddToSearchPath('topology');
 show search_path;
 'search_path';
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1707#comment:15>
