[postgis-devel] [PostGIS] #1468: shp2pgsql-gui append/create/delete/prepare options sitting behind table column
PostGIS trac at osgeo.org
Thu Apr 5 17:07:43 PDT 2012
column
 Reporter:  robe           |       Owner:  mcayland
     Type:  defect         |      Status:  new
 Priority:  low            |   Milestone:  PostGIS 2.0.1
Component:  loader/dumper  |     Version:  trunk
 Keywords:                 |
Changes (by robe):
  * milestone:  PostGIS 2.1.0 => PostGIS 2.0.1
Comment:
 Okay I see the issue here now.  It's the tabs are not opaque so the
 options in the export tab are leaking into the import tab  so when you use
 the drop down, you sometimes accidentally hit the one for export geometry
 column.
 Not sure how easy of a fix this is.  It's not that big of a deal though
 just kinda confusing.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1468#comment:2>
