[postgis-devel] [PostGIS] #1764: overviews not marked as same alignment though main table is
PostGIS trac at osgeo.org
Tue Apr 10 03:33:02 PDT 2012
 Reporter:  robe    |       Owner:  dustymugs
     Type:  defect  |      Status:  assigned
 Priority:  medium  |   Milestone:  PostGIS 2.0.1
Component:  raster  |     Version:  2.0.x
 Keywords:          |
Comment(by robe):
 This is interesting.  I loaded a smaller DEM that is 1000x1000.  I didn't
 chunk it.
 With -l 2,3,4,5  (levels 2,4,5) came in with same alignment = true
 level 3 came in with same_alignment = false
 with 333x333 block size.  I guess because 1/3 goes on forever when
 converted to decimal.  Not sure if that helps any.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1764#comment:2>
