[postgis-devel] ST_Split in 1.5
George Silva georger.silva at gmail.com
Fri Aug 17 06:10:01 PDT 2012
Thanks strk. I got away with ST_Dump and ST_Polygonize.
For future reference:
CREATE OR REPLACE FUNCTION split_polygon(polygon geometry,split_line
geometry) RETURNS SETOF geometry AS
DECLARE
v_geometry geometry;
BEGIN
FOR v_geometry IN SELECT (ST_Dump((
 ST_Polygonize(ST_Union(ST_Boundary(polygon),split_line))
))).geom LOOP
 return next v_geometry;
 END LOOP;
END;
$$ LANGUAGE plpgsql;
On Fri, Aug 17, 2012 at 5:15 AM, Sandro Santilli <strk at keybit.net> wrote:
> I guess the shortest route for you would be to roll your own
> ST_Split in pl/pgsql. There should be something on the wiki
> to start from.
> --strk;
> On Fri, Aug 17, 2012 at 12:39:52AM -0300, George Silva wrote:
> > Hello guys,
> > I've hitted a roadblock with something I'm creating and I need the
> ST_split
> > function in PostGIS 1.5.
> > Is there a way I can make it available for PostGIS 1.5?
> > Do I need to recompile lwgeom?
> > http://svn.osgeo.org/postgis/trunk/postgis/lwgeom_geos.c
> > Or is there a whole lot of other steps to make it work?
> > @strk: any chance you can point me the steps? Thanks
> > George R. C. Silva
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
George R. C. Silva
Desenvolvimento em GIS
http://geoprocessamento.net
http://blog.geoprocessamento.net
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20120817/11fb1bb4/attachment.html>
