[postgis-devel] [PostGIS] #1563: Can't upgrade from alpha3 to alpha4 with extension
PostGIS trac at osgeo.org
Thu Feb 9 06:47:59 PST 2012
 Reporter:  robe                   |       Owner:  robe
     Type:  defect                 |      Status:  new
 Priority:  blocker                |   Milestone:  PostGIS 2.0.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Comment(by dustymugs):
 That'd be my fault.  When I added the out_db boolean column I put it in
 the spot where the extent geometry column was and put extent at the end of
 the column list.  So, feel free to undo that.  I just wanted a clean
 structure for the future.  Sorry.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1563#comment:2>
