[postgis-devel] [PostGIS] #1590: Still regression failures with trunk on mingw
PostGIS trac at osgeo.org
Mon Feb 20 21:19:55 PST 2012
  Reporter:  robe       |       Owner:  pramsey
      Type:  defect     |      Status:  closed
  Priority:  blocker    |   Milestone:  PostGIS 2.0.0
 Component:  postgis    |     Version:  trunk
Resolution:  duplicate  |    Keywords:  mingw, windows
Changes (by robe):
  * status:  new => closed
  * resolution:  => duplicate
Comment:
 found it -- its this one:
 insert into spatial_ref_sys (srid, proj4text) values (500001,NULL);
 insert into spatial_ref_sys (srid, proj4text) values (500002,
 '+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs');
 select '#1150', st_astext(st_transform('SRID=500002;POINT(0 0)',500001));
 I'll close this and reopen that ticket.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1590#comment:1>
