[postgis-devel] circular dependency in doc/ ?
Sandro Santilli strk at keybit.net
Tue Feb 28 11:03:48 PST 2012
On Tue, Feb 28, 2012 at 10:20:19AM -0800, Chris Hodgson wrote:
> Is mathml2.dtd the ONLY thing that was slowing you down strk? There
> are many other DTDs used, eg. docbook and docbook-mathml, and I
> thought that some of those are dependent on eachother, so really the
> solution to this is to properly configure your system's xml catalog.
> It seems like you're going a long way out of your way to work around
> the pre-existing solution of the xmlcatalog.
Indeed it's fast for me now. Could very well be I have all the
other DTDs properly mapped. The new way doesn't replace the old
in any way, just solves my specific situation (it seems).
Is it giving you any problem ?
Surely addin --nonet would expose the issue for anyone having it.
--strk;
  ,------o-.
  |   __/  |    Delivering high quality PostGIS 2.0 !
  |  / 2.0 |    http://strk.keybit.net - http://vizzuality.com
  `-o------'
