[postgis-devel] PostGIS compile problem
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Tue Feb 28 16:04:36 PST 2012
Still can't compile. Where should be defined this POSTGIS_GEOS_VERSION? Can't find it...
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-
> bounces at postgis.refractions.net] On Behalf Of Pierre Racine
> Sent: Tuesday, February 28, 2012 4:52 PM
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] PostGIS compile problem
> $ ./autogen.sh
> * Running /mingw/bin/libtoolize (2.2.10)
>    OPTIONS = --force --copy --install
> libtoolize: putting auxiliary files in `.'.
> libtoolize: copying file `./config.guess'
> libtoolize: copying file `./config.sub'
> libtoolize: copying file `./install-sh'
> libtoolize: copying file `./ltmain.sh'
> libtoolize: putting macros in AC_CONFIG_MACRO_DIR, `macros'.
> libtoolize: copying file `macros/libtool.m4'
> libtoolize: copying file `macros/ltoptions.m4'
> libtoolize: copying file `macros/ltsugar.m4'
> libtoolize: copying file `macros/ltversion.m4'
> libtoolize: copying file `macros/lt~obsolete.m4'
> libtoolize: Consider adding `-I macros' to ACLOCAL_AMFLAGS in Makefile.am.
> * Running /mingw/bin/aclocal (1.11)
> * Running /mingw/bin/autoconf (2.65)
> Now you are ready to run './configure'
> $ ./configure --with-xml2config=/c/projects/libxml/libxml2-
> 2.7.8release/bin/xml2-config --with-
> pgconfig=/c/projects/pg/pg90/bin/pg_config - -with-
> geosconfig=/c/projects/geos/rel-3.3.2/bin/geos-config --with-
> projdir=/c/projects/pg/pg90 --with-gdalconfig=/c/projects/gdal/rel-1.9.0
> /bin/gdal-config
> checking build system type... i686-pc-mingw32 checking host system type...
> i686-pc-mingw32 checking how to print strings... printf checking for gcc... gcc
> checking whether the C compiler works... yes checking for C compiler default
> output file name... a.exe checking for suffix of executables... .exe checking
> whether we are cross compiling... no checking for suffix of object files... o
> checking whether we are using the GNU C compiler... yes checking whether gcc
> accepts -g... yes checking for gcc option to accept ISO C89... none needed
> checking for a sed that does not truncate output... /bin/sed checking for grep
> that handles long lines and -e... /bin/grep checking for egrep... /bin/grep -E
> checking for fgrep... /bin/grep -F checking for ld used by gcc...
> c:/mingw/mingw32/bin/ld.exe checking if the linker
> (c:/mingw/mingw32/bin/ld.exe) is GNU ld... yes checking for BSD- or MS-
> compatible name lister (nm)... /mingw/bin/nm checking the name lister
> (/mingw/bin/nm) interface... BSD nm checking whether ln -s works... yes
> checking the maximum length of command line arguments... 8192 checking
> whether the shell understands some XSI constructs... yes checking whether the
> shell understands "+="... yes checking for c:/mingw/mingw32/bin/ld.exe option
> to reload object files... -r checking for objdump... objdump checking how to
> recognize dependent libraries... file_magic ^x86 archive import|^x86 DLL
> checking for ar... ar checking for strip... strip checking for ranlib... ranlib
> checking for gawk... gawk checking command to parse /mingw/bin/nm output
> from gcc object... ok checking how to run the C preprocessor... gcc -E checking
> for ANSI C header files... yes checking for sys/types.h... yes checking for
> sys/stat.h... yes checking for stdlib.h... yes checking for string.h... yes checking
> for memory.h... yes checking for strings.h... yes checking for inttypes.h... yes
> checking for stdint.h... yes checking for unistd.h... yes checking for dlfcn.h... no
> checking for objdir... .libs checking if gcc supports -fno-rtti -fno-exceptions... no
> checking for gcc option to produce PIC... -DDLL_EXPORT -DPIC checking if gcc
> PIC flag -DDLL_EXPORT -DPIC works... yes checking if gcc static flag -static
> works... yes checking if gcc supports -c -o file.o... yes checking if gcc supports -c
> -o file.o... (cached) yes checking whether the gcc linker
> (c:/mingw/mingw32/bin/ld.exe) supports shared libraries... yes checking
> whether -lc should be explicitly linked in... yes checking dynamic linker
> characteristics... Win32 ld.exe checking how to hardcode library paths into
> programs... immediate checking whether stripping libraries is possible... yes
> checking if libtool supports shared libraries... yes checking whether to build
> shared libraries... yes checking whether to build static libraries... yes checking
> for gcc... (cached) gcc checking whether we are using the GNU C compiler...
> (cached) yes checking whether gcc accepts -g... (cached) yes checking for gcc
> option to accept ISO C89... (cached) none needed checking how to run the C
> preprocessor... gcc -E checking for g++... g++ checking whether we are using the
> GNU C++ compiler... yes checking whether g++ accepts -g... yes checking how to
> run the C++ preprocessor... g++ -E checking for ld used by g++...
> (c:/mingw/mingw32/bin/ld.exe) is GNU ld... yes checking whether the g++ linker
> (c:/mingw/mingw32/bin/ld.exe) supports shared libraries... yes checking for g++
> option to produce PIC... -DDLL_EXPORT -DPIC checking if g++ PIC flag -
> DDLL_EXPORT -DPIC works... yes checking if g++ static flag -static works... yes
> checking if g++ supports -c -o file.o... yes checking if g++ supports -c -o file.o...
> (cached) yes checking whether the g++ linker (c:/mingw/mingw32/bin/ld.exe)
> supports shared libraries... yes checking dynamic linker characteristics... Win32
> ld.exe checking how to hardcode library paths into programs... immediate
> checking for ant... no checking if g++ supports -Wall... yes checking if g++
> supports -Wmissing-prototypes... yes checking if g++ supports -ffloat-store...
> yes checking for flex... flex checking lex output file root... lex.yy checking lex
> library... -lfl checking whether yytext is a pointer... yes checking for bison...
> bison -y checking ieeefp.h usability... no checking ieeefp.h presence... no
> checking for ieeefp.h... no checking termios.h usability... no checking termios.h
> presence... no checking for termios.h... no checking for vasprintf... no checking
> for asprintf... no checking for _LARGEFILE_SOURCE value needed for large
> files... unknown checking for perl... /bin/perl checking for convert...
> /c/Windows/system32/convert checking for xsltproc... no checking for xmllint...
> /c/projects/pg/pg90/bin/xmllint checking for dblatex... no checking
> CUnit/CUnit.h usability... yes checking CUnit/CUnit.h presence... yes checking
> for CUnit/CUnit.h... yes checking for CU_initialize_registry in -lcunit... yes
> checking iconv.h usability... yes checking iconv.h presence... yes checking for
> iconv.h... yes checking for libiconv_open in -liconv... yes checking for iconvctl...
> no checking for libiconvctl... no Using user-specified pg_config file:
> /c/projects/pg/pg90/bin/pg_config checking PostgreSQL version... PostgreSQL
> 9.1.2 checking libpq-fe.h usability... yes checking libpq-fe.h presence... yes
> checking for libpq-fe.h... yes checking for PQserverVersion in -lpq... yes Using
> user-specified xml2-config file: /c/projects/libxml/libxml2-
> checking libxml/tree.h usability... yes
> checking libxml/tree.h presence... yes
> checking for libxml/tree.h... yes
> checking libxml/parser.h usability... yes checking libxml/parser.h presence... yes
> checking for libxml/parser.h... yes checking libxml/xpath.h usability... yes
> checking libxml/xpath.h presence... yes checking for libxml/xpath.h... yes
> checking libxml/xpathInternals.h usability... yes checking libxml/xpathInternals.h
> presence... yes checking for libxml/xpathInternals.h... yes checking for
> xmlInitParser in -lxml2... yes Using user-specified geos-config file:
> checking GEOS version... 3.3.2
> checking geos_c.h usability... yes
> checking geos_c.h presence... yes
> checking for geos_c.h... yes
> checking for initGEOS in -lgeos_c... yes checking whether make sets $(MAKE)...
> yes checking for a BSD-compatible install... /bin/install -c checking for a thread-
> safe mkdir -p... /bin/mkdir -p checking whether NLS is requested... yes checking
> for msgfmt... no checking for gmsgfmt... :
> checking for xgettext... no
> checking for msgmerge... no
> checking for ld used by GCC... c:/mingw/mingw32/bin/ld.exe checking if the
> linker (c:/mingw/mingw32/bin/ld.exe) is GNU ld... yes checking for shared library
> run path origin... done checking for CFPreferencesCopyAppValue... no checking
> for CFLocaleCopyCurrent... no checking for GNU gettext in libc... no checking
> for iconv... yes checking for working iconv... yes checking for GNU gettext in
> libintl... no checking whether to use NLS... no Using user-specified proj
> directory: /c/projects/pg/pg90 checking proj_api.h usability... yes checking
> proj_api.h presence... yes checking for proj_api.h... yes checking for
> pj_get_release in -lproj... yes checking json/json.h usability... no checking
> json/json.h presence... no checking for json/json.h... no checking for
> json_object_get in -ljson... no
> TOPOLOGY: Topology support requested
> checking for GDAL >= 1.6.0... found
> checking for GDALFPolygonize in -lgdal... no
> configure: creating ./config.status
> config.status: creating GNUmakefile
> config.status: creating extensions/Makefile
> config.status: creating extensions/postgis/Makefile
> config.status: creating extensions/postgis/postgis.control
> config.status: creating extensions/postgis_topology/Makefile
> config.status: creating extensions/postgis_topology/postgis_topology.control
> config.status: creating liblwgeom/Makefile
> config.status: creating liblwgeom/cunit/Makefile
> config.status: creating liblwgeom/liblwgeom.h
> config.status: creating libpgcommon/Makefile
> config.status: creating libpgcommon/cunit/Makefile
> config.status: creating postgis/Makefile
> config.status: creating postgis/sqldefines.h
> config.status: creating loader/Makefile
> config.status: creating loader/cunit/Makefile
> config.status: creating topology/Makefile
> config.status: creating regress/Makefile
> config.status: creating doc/Makefile
> config.status: creating doc/Makefile.comments
> config.status: creating doc/html/image_src/Makefile
> config.status: creating utils/Makefile
> config.status: creating java/jdbc/Makefile
> config.status: creating raster/Makefile
> config.status: creating raster/rt_core/Makefile
> config.status: creating raster/rt_pg/Makefile
> config.status: creating raster/loader/Makefile
> config.status: creating raster/test/Makefile
> config.status: creating raster/test/core/Makefile
> config.status: creating raster/test/regress/Makefile
> config.status: creating raster/scripts/Makefile
> config.status: creating raster/scripts/python/Makefile
> config.status: creating postgis_config.h
> config.status: postgis_config.h is unchanged
> config.status: creating raster/raster_config.h
> config.status: raster/raster_config.h is unchanged
> config.status: executing libtool commands
> config.status: executing po-directories commands
>   PostGIS is now configured for i686-pc-mingw32
>  -------------- Compiler Info -------------
>   C compiler:           gcc -g -O2
>   C++ compiler:         g++ -g -O2
>  -------------- Dependencies --------------
>   GEOS config:          /c/projects/geos/rel-3.3.2/bin/geos-config
>   GEOS version:         3.3.2
>   GDAL config:          /c/projects/gdal/rel-1.9.0/bin/gdal-config
>   GDAL version:         1.9.0
>   PostgreSQL config:    /c/projects/pg/pg90/bin/pg_config
>   PostgreSQL version:   PostgreSQL 9.1.2
>   PROJ4 version:        46
>   Libxml2 config:       /c/projects/libxml/libxml2-2.7.8release/bin/xml2-config
>   Libxml2 version:      2.7.8
>   JSON-C support:       no
>   PostGIS debug level:  0
>   Perl:                 /bin/perl
>  --------------- Extensions ---------------
>   PostGIS Raster:       enabled
>   PostGIS Topology:     enabled
>  -------- Documentation Generation --------
>   xsltproc:
>   xsl style sheets:
>   dblatex:
>   convert:              /c/Windows/system32/convert
>   mathml2.dtd:          http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
> > [mailto:postgis-devel- bounces at postgis.refractions.net] On Behalf Of
> > Paul Ramsey
> > Sent: Tuesday, February 28, 2012 4:46 PM
> > Environment, tool-chain? ./autogen, ./configure?
> > P
> > On Tue, Feb 28, 2012 at 1:43 PM, Pierre Racine
> > <Pierre.Racine at sbf.ulaval.ca>
> > wrote:
> > > Hi,
> > > I just updated my geos to this one:
> > > http://download.osgeo.org/geos/geos-3.3.2.tar.bz2
> > > (the svn trunk does not compile) and still PostGIS complain with like this:
> > > /bin/sh ../libtool --mode=compile gcc -g -O2  -DDLL_EXPORT -DPIC
> > > -Wall -Wmissing-prototypes -I/c/projects/geos/rel-3.3.2/include
> > > -I/c/proje cts/pg/pg90/include -c -o lwgeom_geos.lo lwgeom_geos.c
> > > libtool: compile:  gcc -g -O2 -DDLL_EXPORT -DPIC -Wall
> > > -I/c/projects/pg/pg90/inclu de -c lwgeom_geos.c  -DDLL_EXPORT -DPIC
> > > -o .libs/lwgeom_geos.o
> > > lwgeom_geos.c: In function `lwgeom_snap':
> > > lwgeom_geos.c:937: error: `POSTGIS_GEOS_VERSION' undeclared (first
> > > use in this function)
> > > lwgeom_geos.c:937: error: (Each undeclared identifier is reported
> > > only once
> > > lwgeom_geos.c:937: error: for each function it appears in.)
> > > lwgeom_geos.c: In function `lwgeom_sharedpaths':
> > > lwgeom_geos.c:1001: error: `POSTGIS_GEOS_VERSION' undeclared (first
> > > lwgeom_geos.c: In function `LWGEOM2GEOS':
> > > lwgeom_geos.c:265: warning: unreachable code at beginning of switch
> > > statement
> > > make[1]: *** [lwgeom_geos.lo] Error 1
> > > make[1]: Leaving directory `/c/projects/postgis/liblwgeom'
> > > make: *** [all] Error 1
> > > _______________________________________________
> > > postgis-devel mailing list
> > > postgis-devel at postgis.refractions.net
> > > http://postgis.refractions.net/mailman/listinfo/postgis-devel
