[postgis-devel] [PostGIS] #1634: Output confused for the function postgis_full_version()
PostGIS trac at osgeo.org
Wed Feb 29 07:57:33 PST 2012
  Reporter:  lrssvt   |       Owner:  pramsey
      Type:  defect   |      Status:  reopened
  Priority:  medium   |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  2.0.x
Resolution:           |    Keywords:
Comment(by lrssvt):
 Replying to [comment:3 strk]:
 > How did you obtain your sources ?
 Download tar.gz from postgis.refractions.net
 (postgis-2.0.0alpha7SVN.tar.gz)
 > Does the postgis_svn_revision.h contain a sensible revision number ?
 #define POSTGIS_SVN_REVISION 0
 > Does it get updated on "make postgis_svn_revision.h" ?
 Can't fetch local revision (neither .svn nor .git found)
 Not updating existing rev file at 0
 > Did you make install ?
 Yes, i did ./configure, make and make install
 > Did you load postgis_upgrade_20_minor.sql ?
 Yes!
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1634#comment:4>
