[postgis-devel] [PostGIS] #1434: ST_GeomFromGeoJSON - Malformed GeoJSON causes SIGSEGV in postgres process?
trac at osgeo.org
Fri Jan 6 14:52:35 PST 2012
Reporter: tokumine | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: geojson |
Hi all,
I am really enjoying the new ST_GeomFromGeoJSON functionality in
PostGIS2.0SVN.
However, if I try to create geometry with certain types of invalid GeoJSON
I have managed to trigger a SIGSEGV in the postgres process that causes
cascading rollbacks and restarts to all other existing postgres processes.
'''Works:'''
select ST_GeomFromGeoJSON('{ "type": "Point", "coordinates": [100.0, 0.0]
'''Throws 'ERROR: invalid GeoJson representation' as expected:'''
select ST_GeomFromGeoJSON('{ "type": "Poooooooooooooint", "coordinates":
[100.0, 0.0] }');
'''Causes SIGSEGV:'''
select ST_GeomFromGeoJSON('{ "type": "Point", "crashme": [100.0, 0.0] }');
select ST_GeomFromGeoJSON('crashme');
I can trigger this on my Ubuntu and OSX dev machines and attach the OSX
crashlog and the Ubuntu postgres logs for reference.
Please note that occasionally the SQL commands will need to be run a few
times to trigger the SIGSEGV.
All the best,
Simon
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1434>
