[postgis-devel] [PostGIS] #1492: postgis_scripts_installed / postgis_scripts_released are screwy
trac at osgeo.org
Mon Jan 23 04:45:01 PST 2012
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by robe):
I think the perl script scans other includes .sql files. well it used to
before anyway and the reason it was based on files is that before not all
micros required upgrade of sql or at least that was the thinking.
strk -- I really have no time to test without a tag. No tag NO TEST. This
perfection thing has gone on long enough. It's as simple as that. At
least with the version.config (if we have an alpha) thing I have some clue
what I'm testing. I don't now. If we released an alpha when I WANTED
one, I could even do a make check and we'd be all ready for an alpha2
right now (whic is about where we should be). As it stands I can't test
anymore even if I wanted to since the make check stuff is completely
broken for me.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1492#comment:2>
