[postgis-devel] New node splitting algorithm for GiST
Paragon Corporation lr at pcorp.us
Sun Jul 1 06:54:17 PDT 2012
Alex,
Can you attach this to a ticket.  That way Paul won't forget or one of us
can remind him when he does :)
http://trac.osgeo.org/postgis/
Slate it for 2.1.0
Thanks,
Regina
  _____
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of
Alexander Korotkov
Sent: Sunday, July 01, 2012 8:33 AM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] New node splitting algorithm for GiST
On Sat, Jun 30, 2012 at 10:59 PM, Paul Ramsey <pramsey at opengeo.org> wrote:
No progress, still an "item of interest" in my list of things I might
do. If you prepare a compile-time conditional patch, I'd be interested
in reviewing and applying it.
OK, it's here.
Just an small example. Without patch.
test=# create index geonames_idx on geonames using gist (point);
CREATE INDEX
Time: 113796,848 ms
test=# explain (analyze, buffers) select * from geonames where point &&
'BOX(34.4671 126.631,34.5023 126.667)'::box2d::geometry;
QUERY PLAN
 Index Scan using geonames_idx on geonames  (cost=0.00..14.05 rows=2
width=128) (actual time=0.589..0.876 rows=11 loops=1)
   Index Cond: (point &&
'0103000000010000000500000016FBCBEEC93B4140AAF1D24D62A85F4016FBCBEEC93B4140A
69BC420B0AA5F40F163CC5D4B404140A69BC420B0AA5F40F163CC5D4B404140AAF1D24D62A85
F4016FBCBEEC93B4140AAF1D24D62A85F40'::geometry)
   Buffers: shared hit=26
 Total runtime: 0.927 ms
(4 rows)
With patch.
test=# create index geonames2_idx on geonames2 using gist (point);
CREATE INDEX
Time: 118382,076 ms
test=# explain (analyze, buffers) select * from geonames2 where point &&
QUERY PLAN
 Index Scan using geonames2_idx on geonames2  (cost=0.00..22.40 rows=4
width=128) (actual time=0.209..0.225 rows=11 loops=1)
   Buffers: shared hit=11
 Total runtime: 0.276 ms
(4 rows)
With best regards,
Alexander Korotkov.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20120701/6ece68fd/attachment.html>
