[postgis-devel] [PostGIS] #1667: [raster] raster regress failures
PostGIS trac at osgeo.org
Thu Mar 8 04:27:18 PST 2012
 Reporter:  robe                      |       Owner:  pracine
     Type:  defect                    |      Status:  new
 Priority:  blocker                   |   Milestone:  PostGIS 2.0.0
Component:  raster                    |     Version:  trunk
 Keywords:  windows 32-bit, mingw345  |
Comment(by robe):
 Looking at these errors -- these are the same ones I'm getting on the
 64-bit install.  Plus I get one more on that.  I suspect its your change
 to favor using EPSG codes instead of the proj4text that is causing the
 issue.
 In that case it's probably just a gdal configuration that I have to put in
 the path to the data directory (that has all those epsg csv files)?  That
 is a bit annoying since I would have to force people to put in registry
 entries that could possibly screw up their other GDAL stuff.  Wonder if
 there is a way that we can default the path similar to what we do with the
 proj directory.
 strk - I know what you are thinking -- that calls for a GUC, but I think
 we are too late in the game to be introducing GUCs.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1667#comment:2>
