[postgis-devel] [PostGIS] #1668: ST_AsText, ST_AsEWKT under Windows 64-bit PostGIS 64-bit is all screwy
PostGIS trac at osgeo.org
Sun Mar 11 13:24:16 PDT 2012
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  high     |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:  mingw64  |
Comment(by robe):
 So i guess this may affect solaris too huh. How much effor involved to
 make your suggested change.  If a lot and windows 64 is the only one
 affected.
 Here is another solution I found, not sure if this function is accessible
 under mingw64
 http://stackoverflow.com/questions/8488671/unix-to-windows-alternative-to-
 vsnprintf-to-determine-length
 which points to this function:
 http://msdn.microsoft.com/en-us/library/w05tbk72%28VS.71%29.aspx
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1668#comment:21>
