[postgis-devel] topology expectations?
Paul Ramsey pramsey at cleverelephant.ca
Tue Mar 20 15:55:34 PDT 2012
How much should I expect from topology? I just took a polygon file
that had contiguous non-overlapping polygons and did this:
cded=# select TopoGeo_AddPolygon('sheds', st_geometryn(geom,1), 5.0)
from sheds where gis_tag like 'VICT%';
ERROR:  Spatial exception - geometry intersects edge 39
CONTEXT:  PL/pgSQL function "topogeo_addlinestring" line 175 at assignment
SQL statement "SELECT array_cat(edges, array_agg(x)) FROM ( select
topology.TopoGeo_addLinestring(atopology, rec.geom, tol) as x ) as
foo"
PL/pgSQL function "topogeo_addpolygon" line 27 at assignment
This is a non-overlapping set of data, originally generated from
vector clean ArcINFO coverages...
select a.gis_tag, b.gis_tag from sheds a, sheds b where
st_overlaps(a.geom,b.geom) and a.gis_tag like 'VICT%' and b.gis_tag
like 'VICT%';
(0 rows)
Thoughts?
P.
