[postgis-devel] [PostGIS] #1705: Get constraint-based columns in views to register correctly
trac at osgeo.org
Thu Mar 22 06:12:06 PDT 2012
Reporter: robe | Owner: robe
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: postgis | Version: trunk
Keywords: |
right now we have the case (which I've described in the docs)
{{{CREATE TABLE pois_ny(gid SERIAL PRIMARY KEY
, poi_name text, cat varchar(20)
, geom geometry(POINT,4326) );
SELECT AddGeometryColumn('pois_ny', 'geom_2160', 2160, 'POINT', 2, false);
CREATE VIEW vw_pois_ny_parks AS
SELECT *
FROM pois_ny
WHERE cat='park';
SELECT f_table_name, f_geometry_column, srid, type
FROM geometry_columns
WHERE f_table_name LIKE '%pois_ny%';
Yields:
f_table_name | f_geometry_column | srid | type
pois_nyc | geom | 4326 | POINT
pois_ny | geom | 4326 | POINT
pois_ny | geom_2160 | 2160 | POINT
vw_pois_ny_parks | geom | 4326 | POINT
vw_pois_ny_parks | geom_2160 | 0 | GEOMETRY
Observe how the typmod based derived view column registers correctly, but
the constraint based derived one does not.
This is an issue I've been aware of for quite sometime, but haven't
decided if the extra timing needed to do the extra hop for the constraint
based view one is worth it. Sadly I've got a lot of views like this which
I can patch by recreating the view and explicitly casting the column in
the view, but it would be nice if I didn't need to. For many cases, I also
can't convert these to typmod since they involve inheritance hierarchies
where the geometry type of each child table is not the same.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1705>
