[postgis-devel] [PostGIS] #1705: Get constraint-based columns in views to register correctly
PostGIS trac at osgeo.org
Thu Mar 22 06:12:41 PDT 2012
 Reporter:  robe         |       Owner:  robe
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.1.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
Description changed by robe:
Old description:
> right now we have the case (which I've described in the docs)
> {{{CREATE TABLE pois_ny(gid SERIAL PRIMARY KEY
>    , poi_name text, cat varchar(20)
>    , geom geometry(POINT,4326) );
> SELECT AddGeometryColumn('pois_ny', 'geom_2160', 2160, 'POINT', 2,
> false);
> CREATE VIEW vw_pois_ny_parks AS
> SELECT *
>   FROM pois_ny
>   WHERE cat='park';
> SELECT f_table_name, f_geometry_column, srid, type
>         FROM geometry_columns
>         WHERE f_table_name LIKE '%pois_ny%';
> Yields:
>   f_table_name   | f_geometry_column | srid |   type
> pois_nyc         | geom              | 4326 | POINT
> pois_ny          | geom              | 4326 | POINT
> pois_ny          | geom_2160         | 2160 | POINT
> vw_pois_ny_parks | geom              | 4326 | POINT
> vw_pois_ny_parks | geom_2160         |    0 | GEOMETRY
> Observe how the typmod based derived view column registers correctly, but
> the constraint based derived one does not.
> This is an issue I've been aware of for quite sometime, but haven't
> decided if the extra timing needed to do the extra hop for the constraint
> based view one is worth it.  Sadly I've got a lot of views like this
> which I can patch by recreating the view and explicitly casting the
> column in the view, but it would be nice if I didn't need to. For many
> cases, I also can't convert these to typmod since they involve
> inheritance hierarchies where the geometry type of each child table is
> not the same.
New description:
 SELECT AddGeometryColumn('pois_ny', 'geom_2160', 2160, 'POINT', 2, false);
 SELECT *
   FROM pois_ny
   WHERE cat='park';
 Yields:
 based view one is worth it.  Sadly I've got a lot of views like this which
 I can patch by recreating the view and explicitly casting the column in
 the view, but it would be nice if I didn't need to. For many cases, I also
 can't convert these to typmod since they involve inheritance hierarchies
 where the geometry type of each child table is not the same.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1705#comment:1>
