[postgis-devel] [PostGIS] #1706: TopoGeo_AddPolygon not adding polygons
PostGIS trac at osgeo.org
Fri Mar 23 04:01:36 PDT 2012
 Reporter:  pramsey   |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
Comment(by strk):
 And here's some more pictures.
 This is the intersection between the new edge (snapped) and the old one
 (in yellow)
 [[Image(int_new_old.png)]]
 And here's the above intersection (now in red) after snapping self against
 its own endpoints (becomes the yellow one).
 [[Image(wrong_endpoint_snap.png)]]
 Note that the drift from the original is below 3 units (everything
 succeeds with a tolerance of 2)
 With this new informations I might have enough data to try at reproducing
 at smaller scale (with less data). For sure ST_Snap instability has a big
 role in this.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1706#comment:7>
