[postgis-devel] regress!
Sandro Santilli strk at keybit.net
Wed May 23 11:24:03 PDT 2012
On Tue, May 22, 2012 at 06:14:58PM +0200, Olivier Courtin wrote:
> On May 22, 2012, at 5:15 PM, Paul Ramsey wrote:
> > The docs now have an entry for a function signature that ST_AsGML
> > doesn't support anymore, so regression still breaks when the comments
> > are loaded...
> As r9785 it should be better,
> Wrong SQL prototype in postgis.sql.in.c
> My fault, i committed yesterday night, a bit too early...
It still fails for me at r9810 (trunk):
psql:.../regress/00-regress-install/share/contrib/postgis/postgis_comments.sql:364: ERROR:  function st_asgml(integer, geography, integer, integer, text, text) does not exist
Did you fix in 2.0 branch only ?
--strk;
  ,------o-.
  |   __/  |    Delivering high quality PostGIS 2.0 !
  |  / 2.0 |    http://strk.keybit.net - http://vizzuality.com
  `-o------'
