[postgis-devel] Installed GEOS libs on Ubuntu 12.04
Sandro Santilli strk at keybit.net
Wed May 23 23:41:06 PDT 2012
Sounds god to me. Yes, PostGIS will be unaffected.
--strk;
On Wed, May 23, 2012 at 11:37:49PM -0700, maplabs at light42.com wrote:
> Hi All -  if GEOS is built from trunk and installed on a new Ubuntu install,
> then the package manager is used to install
>          libgdal1-1.7.0 libgdal1-dev libgeos-3.2.2 libgeos-c1  libgeos-dev
> the resulting /usr/local/lib looks as follows:
> dbb at r900:~$ ls -l /usr/local/lib
> total 74144
> drwxr-xr-x 2 root root      4096 May 22 20:12 geos
> -rwxr-xr-x 1 root root  18493010 May 22 20:11 libgeos-3.4.0dev.so
> -rw-r--r-- 1 root root  50322836 May 22 20:12 libgeos.a
> -rw-r--r-- 1 root root   2239188 May 22 20:12 libgeos_c.a
> -rwxr-xr-x 1 root root       979 May 22 20:12 libgeos_c.la
> lrwxrwxrwx 1 root root        18 May 22 20:12 libgeos_c.so ->
> libgeos_c.so.1.8.0
> lrwxrwxrwx 1 root root        18 May 22 20:12 libgeos_c.so.1 ->
> libgeos_c.so.1.8.0
> -rwxr-xr-x 1 root root   1051542 May 22 20:12 libgeos_c.so.1.8.0
> -rwxr-xr-x 1 root root       956 May 22 20:11 libgeos.la
> lrwxrwxrwx 1 root root        19 May 22 20:11 libgeos.so ->
> libgeos-3.4.0dev.so
> -rw-r--r-- 1 root root   2519854 May 22 20:13 libproj.a
> -rwxr-xr-x 1 root root       943 May 22 20:13 libproj.la
> lrwxrwxrwx 1 root root        16 May 22 20:13 libproj.so -> libproj.so.0.7.0
> lrwxrwxrwx 1 root root        16 May 22 20:13 libproj.so.0 -> libproj.so.0.7.0
> -rwxr-xr-x 1 root root   1261167 May 22 20:13 libproj.so.0.7.0
> drwxr-xr-x 2 root root      4096 May 22 20:13 pkgconfig
> drwxrwsr-x 4 root staff     4096 May 21 11:31 python2.7
> drwxrwsr-x 3 root staff     4096 May 23 23:27 R
> Q. Is this a useable state of affairs?
> also, will PostGIS built from source against libgeos-3.4.0dev remain
> unaffected?
