[postgis-devel] [PostGIS] #1999: Crash on LINESTRING with one point
PostGIS trac at osgeo.org
Wed Nov 7 12:17:45 PST 2012
 Reporter:  realityexists  |       Owner:  pramsey
     Type:  defect         |      Status:  new
 Priority:  medium         |   Milestone:  PostGIS 2.1.0
Component:  postgis        |     Version:  trunk
 Keywords:                 |
Comment(by pramsey):
 So, why does this require a fancy function to unearth? Doesn't running
 SELECT 'LINESTRING(0 0)'::geometry;
 a couple times do it? Can you capture the crash in gdb and get a stack-
 trace? That would be a first hint of where things go off the rails (though
 it's pretty clearly a memory corruption problem, so it could be really
 hard to figure out).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1999#comment:7>
