[postgis-devel] Fwd: ST_DumpPoints in C
Sandro Santilli strk at keybit.net
Mon Oct 15 11:35:54 PDT 2012
On Mon, Oct 15, 2012 at 06:20:18PM +0000, Nathan Wagner wrote:
> On Mon, Oct 15, 2012 at 11:00:29AM -0700, Paul Ramsey wrote:
> > It's not mine, it's Nathan's...
> > the URL to clone is
> > https://pd.if.org/git/dumppoints
> > and it's not a patch on PostGIS, it's an extension that depends on PostGIS
> I thought it would make testing and use easier if it could be
> vetted as an extension before it was merged into PostGIS proper.
> I've only tested against Postgres 9.2 and postgis 2.0.  I don't
> see any particular reason why it wouldn't work with other versions,
> but I may have used some lwgeom functions or struct members that
> are particular to 2.0.
If you maintained a fork of the git repo currently on github it would
have been easier to test, and less integration work for merging in...
--strk;
 http://www.cartodb.com - Map, analyze and build applications with your data
                                       ~~ http://strk.keybit.net
