[postgis-devel] [PostGIS] #1997: regression failures under windows 9.2 64-bit release
PostGIS trac at osgeo.org
Sat Sep 15 23:45:44 PDT 2012
  Reporter:  robe      |       Owner:  pramsey
      Type:  defect    |      Status:  reopened
  Priority:  critical  |   Milestone:  PostGIS 2.0.2
 Component:  postgis   |     Version:  trunk
Resolution:            |    Keywords:
Changes (by robe):
  * status:  closed => reopened
  * resolution:  invalid =>
  * milestone:  PostGIS 2.1.0 => PostGIS 2.0.2
Comment:
 Okay something else wrong here.  Winnie is doing fine on regressing 32-bit
 9.2 but coughing with regressing the 9.2 64bit. idon't recall this issue
 with the rc1s.
 Inspection of failures, are crashes of the backend.  I'm having similar
 issue with building the 2.0.1 64-bit for 9.2 on my windows 7 64-bit.  The
 annoying thing is if I run the statements manually that cause the crash,
 they don't crash.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1997#comment:2>
