[postgis-devel] Ack! postgis.control is not getting install!
Stephen Woodbridge
woodbri at swoodbridge.com
Sat Jun 8 08:13:53 PDT 2013
OK, Below is what I did and what's in the extensions and contrib
directories. I can not install 2.1 at all as an extenstion because the
control file and all the sql files are missing.
-Steve
# old beta3 may 23rd that worked installed
cd postgis-2.1.0beta3dev
sudo make uninstall
cd ..
rm -rf postgis-2.1.0beta3dev
wget http://postgis.net/stuff/postgis-2.1.0beta3dev.tar.gz
tar xzf postgis-2.1.0beta3dev.tar.gz
./configure --with-pgconfig=/usr/lib/postgresql/9.2/bin/pg_config
make
sudo make install
And this is what I now have in my /usr/share/postgresql/9.2/extension/
related to postgis.
postgis--2.0.0--2.0.3.sql
postgis--2.0.0alpha1--2.0.3.sql
postgis--2.0.0alpha2--2.0.3.sql
postgis--2.0.0alpha3--2.0.3.sql
postgis--2.0.0alpha4--2.0.3.sql
postgis--2.0.0alpha5--2.0.3.sql
postgis--2.0.0alpha6--2.0.3.sql
postgis--2.0.0beta1--2.0.3.sql
postgis--2.0.0beta2--2.0.3.sql
postgis--2.0.0beta3--2.0.3.sql
postgis--2.0.0beta4--2.0.3.sql
postgis--2.0.0rc1--2.0.3.sql
postgis--2.0.0rc2--2.0.3.sql
postgis--2.0.1--2.0.3.sql
postgis--2.0.2--2.0.3.sql
postgis--2.0.3.sql
postgis_tiger_geocoder--2.0.0--2.1.0beta3dev.sql
postgis_tiger_geocoder--2.0.1--2.1.0beta3dev.sql
postgis_tiger_geocoder--2.0.2--2.1.0beta3dev.sql
postgis_tiger_geocoder--2.0.3--2.1.0beta3dev.sql
postgis_tiger_geocoder--2.1.0beta1--2.1.0beta3dev.sql
postgis_tiger_geocoder--2.1.0beta3dev--2.1.0beta3devnext.sql
postgis_tiger_geocoder--2.1.0beta3devnext--2.1.0beta3dev.sql
postgis_tiger_geocoder--2.1.0beta3dev.sql
postgis_tiger_geocoder--2.1.0SVN--2.1.0beta3dev.sql
postgis_tiger_geocoder.control
postgis_tiger_geocoder--unpackaged--2.1.0beta3dev.sql
postgis_topology--2.0.0--2.0.3.sql
postgis_topology--2.0.0--2.1.0beta3dev.sql
postgis_topology--2.0.0alpha1--2.0.3.sql
postgis_topology--2.0.0alpha2--2.0.3.sql
postgis_topology--2.0.0alpha3--2.0.3.sql
postgis_topology--2.0.0alpha4--2.0.3.sql
postgis_topology--2.0.0alpha5--2.0.3.sql
postgis_topology--2.0.0alpha6--2.0.3.sql
postgis_topology--2.0.0beta1--2.0.3.sql
postgis_topology--2.0.0beta2--2.0.3.sql
postgis_topology--2.0.0beta3--2.0.3.sql
postgis_topology--2.0.0beta4--2.0.3.sql
postgis_topology--2.0.0rc1--2.0.3.sql
postgis_topology--2.0.0rc2--2.0.3.sql
postgis_topology--2.0.1--2.0.3.sql
postgis_topology--2.0.1--2.1.0beta3dev.sql
postgis_topology--2.0.2--2.0.3.sql
postgis_topology--2.0.2--2.1.0beta3dev.sql
postgis_topology--2.0.3--2.1.0beta3dev.sql
postgis_topology--2.0.3.sql
postgis_topology--2.1.0beta1--2.1.0beta3dev.sql
postgis_topology--2.1.0beta3dev--2.1.0beta3devnext.sql
postgis_topology--2.1.0beta3devnext--2.1.0beta3dev.sql
postgis_topology--2.1.0beta3dev.sql
postgis_topology--2.1.0SVN--2.1.0beta3dev.sql
postgis_topology.control
postgis_topology--unpackaged--2.0.3.sql
postgis_topology--unpackaged--2.1.0beta3dev.sql
postgis--unpackaged--2.0.3.sql
And in the contrib I have:
ls /usr/share/postgresql/9.2/contrib/postgis*
/usr/share/postgresql/9.2/contrib/postgis-2.0:
legacy_gist.sql rtpostgis_upgrade_20_minor.sql
legacy_minimal.sql spatial_ref_sys.sql
legacy.sql topology_comments.sql
postgis_comments.sql topology.sql
postgis_restore.pl topology_upgrade_20_minor.sql
postgis.sql uninstall_legacy.sql
postgis_upgrade_20_minor.sql uninstall_postgis.sql
raster_comments.sql uninstall_rtpostgis.sql
rtpostgis_legacy.sql uninstall_topology.sql
rtpostgis.sql
/usr/share/postgresql/9.2/contrib/postgis-2.1:
legacy_gist.sql rtpostgis_upgrade_20_21.sql
legacy_minimal.sql rtpostgis_upgrade_21_minor.sql
legacy.sql spatial_ref_sys.sql
postgis_comments.sql topology_comments.sql
postgis_restore.pl topology.sql
postgis.sql topology_upgrade_21_minor.sql
postgis_upgrade_20_21.sql uninstall_legacy.sql
postgis_upgrade_21_minor.sql uninstall_postgis.sql
rtpostgis_legacy.sql uninstall_sfcgal.sql
rtpostgis.sql uninstall_topology.sql
On 6/8/2013 10:50 AM, Paragon Corporation wrote:
> Guys,
> Sorry about this I'll check on this issue why no control file. No
> postgis-2.1.0beta3dev is not stable. That is why I put a dev at the end
> of it.
> The one you want to use for stability has no dev --- postgis-2.1.0beta2
> http://www.postgis.net/2013/05/11/postgis-2-1-0beta2
> Sorry for the confusion. I changed from our standard development
> extension (SVN to dev) in case one day we won't be using SVN.
> As a general rule, we always put our tagged builds on our osgeo download
> site.
> Thanks,
> Regina
> *From:* postgis-devel-bounces at lists.osgeo.org
> [mailto:postgis-devel-bounces at lists.osgeo.org] *On Behalf Of *Daniel Kastl
> *Sent:* Saturday, June 08, 2013 10:16 AM
> *To:* PostGIS Development Discussion
> *Subject:* Re: [postgis-devel] Ack! postgis.control is not getting install!
> On Sat, Jun 8, 2013 at 11:03 PM, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
> Hi Dev,
> The current postgis-2.1.0beta3dev.tar.gz and svn are not installing
> the postgis.control file. The other two control files are there.
> Poor Daniel has been setting a travis instance for pgrouting and
> puzzling over this issue because we require pulling 2.1 and doing a
> local build and install from that for pgrouting. So I guess we
> running a postgis build-bot also :)
> Well, Steve told me that the postgis-2.1.0beta3dev.tar.gz is changing
> every night, which explains that it worked still 4 days ago. I thought
> it would be a "stable" beta.
> As a Travis newbie I thought I messed up something with the install
> script ;-)
> Daniel
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
> Web: http://georepublic.de <http://georepublic.de/>
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
