[postgis-devel] SNapPointToLine : GEOS : where is the code for st_intersects between line and point?
Rémi Cura remi.cura at gmail.com
Wed Nov 6 01:22:02 PST 2013
Am I right to suppose that this is the code in LineIntersector.cpp
function LineIntersector::HasIntersection
CGAlgorithms::orientationindex
RobustDeterminant::SIgnOfDet2x2
Cheers,
Rémi-C
2013/11/6 Rémi Cura <remi.cura at gmail.com>
> Hey,
> I've been working on a ST_SnapPointToLine for the past week,
> by reverse engineering when points are considered to be on line by
> st_intersect.
> The (classic) problem is purely a numerical issue, and I suspect a problem
> in design of st_intersects.
> So far my solution doesn't work for all line, can someone please point me
> in the right direction in GEOS so I can see if something can be improved
> regarding precision.
> I know where the API is, but I'm looking for the exact part that decide if
> a point and a line intersects.
> Cheers,
> Rémi-C
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20131106/4925f0a1/attachment.html>
