[postgis-devel] [postgis-users] linking 2 topogeometries of different nature
Rémi Cura remi.cura at gmail.com
Tue Oct 22 06:28:00 PDT 2013
(switching to devel list)
What would you think of 2 functions :
GetRelatedPuntal(Lineal)
GetRelatedLineal (Puntal)
This function would allow, when having a lineal, to get puntal sharing a
node;
and when having a puntal, to get part of a lineal sharing node with it.
precise signature being :
SET OF id_topogeom GetRelatedLineal( a_puntal_topogeom_name,
a_puntal_topogeom_layer_id )
same for puntal
Cheers,
Rémi-C
2013/10/22 Rémi Cura <remi.cura at gmail.com>
> Hello Sandro,
> I'll surely do things the way you suggest, I realize it is what makes the
> most sense for me.
> Thanks for the quick answer !
> Cheers,
> Rémi-C
> 2013/10/22 Sandro Santilli <strk at keybit.net>
>> On Tue, Oct 22, 2013 at 01:51:53PM +0200, Rémi Cura wrote:
>> > Hey dear List,
>> > (and hey Sandro ;-) )
>> > somebody knows if there is a mechanism to make explicit link between 2
>> > topogeoms of different type (lineal and puntal)?.
>> > For instance in a road network with topogeom "road" and topogeom
>> > "road_intersection", I would like to link the "road_intersection" to all
>> > incoming/outcoming "road".
>> > I was thinking of using classical relations (foregin key etc), but maybe
>> > there is something I don't understand.
>> > I'm going to do this a lot so I would appreciate suggestions making it
>> > compatible with current postgis_topology functionning.
>> The TopoGeometry type was created mostly to let people deal with them
>> the way they used to deal with Geometry objects, so you can use classical
>> relations.
>> BUT if you get down one level you can use GetNodeEdges against a node
>> associated
>> with a "road_intersection" value to obtain a list of edge identifiers,
>> and then
>> go back up to find linear TopoGeometry objects whose definition include
>> those
>> edge identifiers. Those relations are already there, it's only your
>> choice to
>> use them.
>> --strk;
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20131022/8e86821e/attachment.html>
