[postgis-devel] PSC/Development Vote -- Baris to release upcoming 2.1.3 jars and manually sign
Baris Ergun barisergun75 at gmail.com
Thu Apr 24 03:41:53 PDT 2014
Okey than will start soon.
On 22 April 2014 22:38, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> make it so +1
> On Sat, Apr 19, 2014 at 5:52 PM, Bborie Park <dustymugs at gmail.com> wrote:
> > +1 for release of 2.1.3 jar.
> > On Sat, Apr 19, 2014 at 5:47 PM, Paragon Corporation <lr at pcorp.us>
> wrote:
> >> Baris,
> >> Regarding this:
> >> > Here is my proposal: I can take care of the last  targeted 2.1 release
> >> > which is 2.1.3 and change pom.xmls as I did in the trunk and apply
> shanes
> >> > patches and after the release of 2.1.3 I can manually sign the jars
> and
> >> > submit them to OSSRH. And keep discussing the separation of
> >> > repositories on trunk.
> >> +1 for that.  Others in PSC and development please vote on this as well
> so
> >> we can start moving on this.
> >> I think we'll be releasing a 2.1.3 fairly soon.  2.2.0 we are looking at
> >> at least another 4 months and that's being hopeful :)
> >> Thanks,
> >> Regina
> >> http://www.postgis.us
> >> http://postgis.net
> >> ________________________________
> >> From: postgis-users-bounces at lists.osgeo.org
> >> [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Baris Ergun
> >> Sent: Saturday, April 19, 2014 4:50 AM
> >> To: PostGIS Users Discussion
> >> Cc: PostGIS Development Discussion
> >> Subject: Re: [postgis-users] [postgis-devel] looking for a public well
> >> known maven repository for postgis-jdbc 2.1 and later on versions
> >> Hi Shane;
> >> People are busy with other stuff so until we decide to separate the
> >> repositories for postgis java projects I have applied ur patches to both
> >> jdbc and jdbc_jtsparser projects. So what this means is "when we release
> >> 2.2.0 postgis I would be ready to submit these two jars manually to
> OSSRH".
> >> Baris
> >> On 7 April 2014 21:26, Shane StClair <shane at axiomalaska.com> wrote:
> >>> Hi Baris,
> >>> Oops, I didn't see that you were already chasing this down. Your
> approach
> >>> sounds great, thanks for taking the lead on this! In the past there
> have
> >>> been issues with other projects having non-resolvable dependencies on
> >>> versions of postgis-jdbc (Hibernate Spatial), so it will be great to
> have
> >>> these artifacts in the central repo.
> >>> Best,
> >>> Shane
> >>> On Sun, Apr 6, 2014 at 2:29 AM, Baris Ergun <barisergun75 at gmail.com>
> >>> wrote:
> >>>> Hi Shane;
> >>>> Thanks for ur patch and consideration. I think we are on the same path
> >>>> if u check the issue #2626. I have applied the OSSRH and got the
> credentials
> >>>> for being able to upload postgis jdbc jars to central maven rep. For
> that
> >>>> case I have separated the jdbc and jdbc-jtsparser jars on the trunk
> and
> >>>> updated the pom.xml's according to Central maven repository
> requirements..
> >>>> On the trunk actually I was waiting to agree  with all the developers
> to
> >>>> separate the postgis jdbc jars  repository and continue with 1st
> suggested
> >>>> approach.  If we do that way we wouldnt need to make the explicit
> plugin
> >>>> declarations as you patched in 2702.
> shanes
> and
> repositories on
> >>>> trunk.
> >>>> On 6 April 2014 05:32, Paragon Corporation <lr at pcorp.us> wrote:
> >>>>> I don't have any objections.  +1 for that.
> >>>>> Thanks,
> >>>>> Regina
> >>>>> [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Shane
> StClair
> >>>>> Sent: Saturday, April 05, 2014 5:24 PM
> >>>>> Subject: Re: [postgis-users] looking for a public well known maven
> >>>>> Sounds good. Any objection to the community manually uploading
> pre-2.2
> >>>>> versions to Maven Central?
> >>>>> Thanks,
> >>>>> Shane
> >>>>> On Sat, Apr 5, 2014 at 1:38 PM, Paragon Corporation <lr at pcorp.us>
> >>>>> wrote:
> >>>>>> Shane,
> >>>>>> I think we can change our build bot to upload to maven as part of
> the
> >>>>>> official release job when we build tagged docs etc.  Have to talk
> over with
> >>>>>> rest of PostGIS psc and dev folks on that.
> >>>>>> I guess before that we'll need to completely cleanup the issues with
> >>>>>> our current jdbc which sounds like we are close.  Thanks for the
> patch BTW.
> >>>>>> Thanks,
> >>>>>> Regina Obe
> >>>>>> PostGIS PSC member
> >>>>>> http://postgis.net
> StClair
> >>>>>> Sent: Saturday, April 05, 2014 3:29 PM
> >>>>>> To: postgis-users at lists.osgeo.org
> >>>>>> Subject: [postgis-users] looking for a public well known maven
> >>>>>> I just submitted a patch [1] to generate javadoc and source jars as
> >>>>>> part of the postgis-jdbc build. Otherwise, the existing pom meets
> the Maven
> >>>>>> Central sync requirements [2].
> >>>>>> There are two options for getting up to date postgis-jdbc releases
> >>>>>> into Maven Central. The first would be for Maven Central deployment
> to
> >>>>>> become part of the postgis release process. After the initial setup
> the
> >>>>>> Maven Central publishing process isn't terribly painful, but it
> would
> >>>>>> require a postgis developer to assume responsibility for the Maven
> Central
> >>>>>> submission and for postgis-jdbc to get special consideration during
> releases
> >>>>>> [3] [4].
> >>>>>> The other option would be to have the community manually upload to
> >>>>>> Maven Central [5]. This is definitely not the ideal situation, but
> if Maven
> >>>>>> Central uploads are out of scope for the postgis devs right now it
> would
> >>>>>> allow us to get updated versions into the central repo. A blessing
> from the
> >>>>>> postgis devs would help in this second case.
> >>>>>> Thanks,
> >>>>>> Shane
> >>>>>> [1] http://trac.osgeo.org/postgis/ticket/2702
> >>>>>> [2]
> https://docs.sonatype.org/display/Repository/Central+Sync+Requirements
> >>>>>> [3]
> https://maven.apache.org/guides/mini/guide-central-repository-upload.html
> >>>>>> [4] http://central.sonatype.org/pages/ossrh-guide.html
> >>>>>> [5]
> https://docs.sonatype.org/display/Repository/Uploading+3rd-party+Artifacts+to+The+Central+Repository
> >>>>>> Shane StClair
> >>>>>> Software Engineer
> >>>>>> Axiom Consulting & Design
> >>>>>> http://www.axiomalaska.com
> >>>>>> _______________________________________________
> >>>>>> postgis-users mailing list
> >>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> >>>>> Shane StClair
> >>>>> Software Engineer
> >>>>> postgis-devel mailing list
> >>>>> postgis-devel at lists.osgeo.org
> >>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
> >>>> Barış
> >>> Shane StClair
> >>> Software Engineer
> >> Barış
Barış
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140424/21fe53bd/attachment.html>
