[postgis-devel] address standardizer extension
Sandro Santilli strk at keybit.net
Wed Aug 27 02:17:48 PDT 2014
Is it normal for the address standardizer extension to not be built
automatically on "make" ? I ask because it is found under the extension/
dir. If it's not to be integrated it should reside in the extra/ dir instead.
--strk;
 ()  ASCII ribbon campaign  --  Keep it simple !
 /\  http://strk.keybit.net/rants/ascii_mails.txt
