[postgis-devel] Postgis Raster JPEG 2000 (openjpeg)
Nathaniel Clay clay.nathaniel at gmail.com
Tue Feb 18 09:55:53 PST 2014
On Tue, Feb 18, 2014 at 11:24 AM, Bborie Park <dustymugs at gmail.com> wrote:
> How does OpenJPEG 2000 compare to other formats, such as GeoTIFF, HDF5 or
> NetCDF?
 All of the mentioned, formats use libz compression, a loss less
compression scheme. With the exception that GTiff offers plain jpeg
compression along with a fax format??
I think it may be a good idea to also ofter libz (deflate) and or LZMA
compression.
Before I move on to the next questions a little background on my thought
process.
I see three different use types:
1. Active Server
Before deciding on a replacement format, we should identify if a
> replacement is required? What are the current short-comings? Where are the
> performance limitations? What are the wish-list items for a replacement
> format?
> I have spent some time at poking at what I considered short-comings, where
> I think performance is suffering, and what features are missing. I'm not
> ready to publicly share my list though.
> I wasn't involved with the original PostGIS raster binary format but from
> my understanding while working it with, it appears as though the goal was
> to keep things simple as all input and output goes through PostgreSQL,
> which can (should?) be considered a black-box.
> -bborie
> On Mon, Feb 17, 2014 at 6:32 PM, Nathaniel Clay <clay.nathaniel at gmail.com>wrote:
>> Hi all,
>> This is just some food for thought and discussion. I've take a cursory
>> look at JPEG 2000 openjpeg. I think it may hold promise for a possible
>> future format or co-format for Postgis Raster in database storage.
>>    - Supports both Loss less and Lossful Compression approaching the
>>    performance of ERDAS ( uncompressed Gtif 200M, openjpeg JP2  25M Lossfull
>>    and 80M Lossless, ERDAS JP2 15M)
>>       - I don't have a ERADAS encoder license, but this image was of the
>>       same original
>>       - Openjpeg lossfull compression in my opinion visually identical
>>       to the original with default settings
>>       - Supports N band imagery
>>    - Multi-Resolution Packing
>>    - eg more than one raster resolution with in the "code stream"
>>       - can be ordered by user specification, default smallest to largest
>>       - This would allow us to get rid of the overview tables or make
>>       them views.
>>       http://ericportis.com/posts/2014/resolution-progressive-jpeg2000-performance/
>>       - Extensible header
>>       - SRID, IPX,IPY, etc
>>       - Area of interest specification
>>       - Allows you to specify a region with in the same raster to have a
>>       higher bitrate, etc
>>    - Error Detection and Correction
>>    - Openjpeg project seems to be alive last commit was a few days a go.
>>    - BSD License
>> Possible Concerns identified so far:
>>    - Writes require a recode of the entire tile, however the tile size
>>    is user specifiable
>>    - takes a long time to encode image, ~10 sec on my system with the
>>    test image ( 3067x3777 8bit 4bands)
>>       - I dont have anything to compare it to, so I dont know if this is
>>       a good or bad
>>       - I havent tested on small image size and other possible
>>       scenarios.
>>       - Memory Usage seemed high during decode and encode, ~2G, I
>>    believe this is due to the decoder and encoder preallocate memory for all
>>    of the "Pyramids" and bands at once. (but have not investigated thoroughly)
>>    ( Image Res 3067x 3777  8bit  4 bands)
>>    - Its included decoder application has weird issues with tif, other
>>    formats are fine. ( Dont think it has anything to do with the openjpeg lib)
>>       - May be indective of other problems
>> If I were to start on this project it would be some time in the future
>> and I would most likely require help and lots of input, but I thought I it
>> would be a good idea to bring, it up as a discussion point.
>> Any thoughts,
>> Nathaniel Hunter Clay
>> postgis-devel mailing list
>> postgis-devel at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140218/f52542c9/attachment.html>
