[postgis-devel] Reg : Error while doing " create extension postgis; "
Manikanta Kondeti mani.iiit123 at gmail.com
Sat Jan 25 12:53:35 PST 2014
Hello sir ,
      I heard that if add that repositories  cmake wont work & it will
remove all libraries linked with it . I have done a web application using
pgrouting in oct & nov , at that time I remember I had these libraries in
my system and it worked perfectly . In this month I was about to do my lab
work which needs cmake  , so I installed it again & it removed all the
libararies linked with pgrouting . I got this information from ubuntu
people in IRC. Is there any alternative way ,   Now what shall I do ??
Thank you ,
Manikanta
Spatial Informatics ,
IIIT-H
On Sat, Jan 25, 2014 at 7:52 PM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> On 1/25/2014 5:46 AM, Manikanta Kondeti wrote:
>> Hello ,
>>       I am getting this error while installing a pgrouting algorithm
>> which is developed last year . I have also attached a screenshot of it
>> which shows the error .
>> Error :    could not load library
>> "/usr/lib/postgresql/9.1/lib/rtpostgis-2.0.so
>> <http://rtpostgis-2.0.so>": /usr/local/lib/libgdal.so.1: version
>> `GDAL_1.8' not found (required by
>> /usr/lib/postgresql/9.1/lib/rtpostgis-2.0.so <http://rtpostgis-2.0.so>)
> I would recommend adding adding the following ppa's
> http://ppa.launchpad.net/georepublic/pgrouting/ubuntu precise
> http://ppa.launchpad.net/ubuntugis/ppa/ubuntu precise
> http://apt.postgresql.org/pub/repos/apt/ precise-pgdg
> This should make the latest gis stack available on Ubuntu.
> -Steve W
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140126/9517c9d9/attachment.html>
