[postgis-devel] ST_Intersection failing on valid geometries
Komяpa me at komzpa.net
Fri Jun 27 04:48:09 PDT 2014
2014-06-27 14:21 GMT+03:00 Rémi Cura <remi.cura at gmail.com>:
> Seems like a precision issue.
> Can you try to translate your  geometry and round theim (ST_SnpaToGrid) a
> bit to reduce the number of digits?
I'd prefer not to, as
a) this is intermediate step in more complex processing;
b) I bumped into this issue multiple times, and now I have a testing
case dataset.
Can something be done inside PostGIS not to fail on such geometries?
> Cheers,
> Rémi-C
> 2014-06-27 12:18 GMT+02:00 Komяpa <me at komzpa.net>:
>> Hi,
>> I managed to create a set of geometries that I'd like to intersect.
>> POSTGIS="2.1.3 r12547" GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel. 4.8.0,
>> 6 March 2012" GDAL="GDAL 1.11.0, released 2014/04/16" LIBXML="2.9.1"
>> LIBJSON="UNKNOWN" (core procs from "2.1.2 r12389" need upgrade)
>> TOPOLOGY (topology procs from "2.1.2 r12389" need upgrade) RASTER
>> (raster procs from "2.1.2 r12389" need upgrade)
>> Test table:
>> http://pastebin.com/qSYLGfvs
>> After that:
>> select ST_Intersection(p.geom, g.geom) from bad_intersections p,
>> bad_intersections g;
>> ERROR:  XX000: Error performing intersection: TopologyException: found
>> non-noded intersection between LINESTRING (1.45784e+07 -1.40333e+06,
>> 1.45784e+07 -1.40333e+06) and LINESTRING (1.45784e+07 -1.40333e+06,
>> 1.45784e+07 -1.40333e+06) at 14578380.693885569 -1403332.55464
>> LOCATION:  pg_error, lwgeom_pg.c:162
>> Time: 10,674 ms
>> All geometries are valid.
>> Can this be fixed?
>> Darafei "Komяpa" Praliaskouski
>> OSM BY Team - http://openstreetmap.by/
>> xmpp:me at komzpa.net mailto:me at komzpa.net
>> postgis-devel mailing list
>> postgis-devel at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
