[postgis-devel] ST_Intersection failing on valid geometries
Rémi Cura remi.cura at gmail.com
Fri Jun 27 04:21:26 PDT 2014
Seems like a precision issue.
Can you try to translate your  geometry and round theim (ST_SnpaToGrid) a
bit to reduce the number of digits?
Cheers,
Rémi-C
2014-06-27 12:18 GMT+02:00 Komяpa <me at komzpa.net>:
> Hi,
> I managed to create a set of geometries that I'd like to intersect.
> POSTGIS="2.1.3 r12547" GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel. 4.8.0,
> 6 March 2012" GDAL="GDAL 1.11.0, released 2014/04/16" LIBXML="2.9.1"
> LIBJSON="UNKNOWN" (core procs from "2.1.2 r12389" need upgrade)
> TOPOLOGY (topology procs from "2.1.2 r12389" need upgrade) RASTER
> (raster procs from "2.1.2 r12389" need upgrade)
> Test table:
> http://pastebin.com/qSYLGfvs
> After that:
> select ST_Intersection(p.geom, g.geom) from bad_intersections p,
> bad_intersections g;
> ERROR:  XX000: Error performing intersection: TopologyException: found
> non-noded intersection between LINESTRING (1.45784e+07 -1.40333e+06,
> 1.45784e+07 -1.40333e+06) and LINESTRING (1.45784e+07 -1.40333e+06,
> 1.45784e+07 -1.40333e+06) at 14578380.693885569 -1403332.55464
> LOCATION:  pg_error, lwgeom_pg.c:162
> Time: 10,674 ms
> All geometries are valid.
> Can this be fixed?
> Darafei "Komяpa" Praliaskouski
> OSM BY Team - http://openstreetmap.by/
> xmpp:me at komzpa.net mailto:me at komzpa.net
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140627/a6a1bda3/attachment.html>
