[postgis-devel] update topology locally
Rémi Cura remi.cura at gmail.com
Tue Feb 17 01:29:59 PST 2015
Ahaha,
in my interior self i __knew__ you wouldn't like the html background color,
but I couldn't stop myself nonetheless
Cheers,
Rémi-C
2015-02-16 19:25 GMT+01:00 Sandro Santilli <strk at keybit.net>:
> On Mon, Feb 16, 2015 at 07:04:45PM +0100, Rémi Cura wrote:
> >    (Batch creation from linestring:
> >    node with GEOS,A
> >    insert node into topology
> >    cut linestring into pieces with nodes (various option, GEOS would be
> best)
> >    insert linestring pieces as edge, with only start_node and end_node
> >    correct
> >    compute edge_linking and face-linking
> >    I already have everything in yellow.
> Pity neither ASCII nor UTF8 have provision for colors :)
> --strk;
>  ()  ASCII ribbon campaign  --  Keep it simple !
>  /\  http://strk.keybit.net/rants/ascii_mails.txt
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20150217/48370c08/attachment.html>
