[postgis-devel] postgis extension sans raster (only for folks who can't compile with raster support) - PSC Vote and developer/packager comments please
Paul Ramsey pramsey at cleverelephant.ca
Fri Oct 30 09:06:44 PDT 2015
If this has all be incited by the QT issue, the +100 on this. It’s a build problem, not a dependency problem in that case.
P
On October 30, 2015 at 8:58:09 AM, Pierre Racine (pierre.racine at sbf.ulaval.ca) wrote:
I think Even`s comment was skipped too fast. If GDAL has no dependency on QT and the problem comes from the fact they compile it with QT then THEY should fix the way they compile GDAL instead of having many projects based on GDAL to adapt to their particular situation.
Paul Ramsey
Sent with Airmail
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20151030/abb2dafc/attachment.html>
