[postgis-devel] Current master branch of postgis causing clone issues ?
Regina Obe lr at pcorp.us
Thu Aug 25 12:33:37 PDT 2016
I'm thinking it's still the git mirroring that converted  CRLF to LF.  So might be something strk needs to look into since he's in charge of the mirroring to github.
Looking at the file locally that I committed to SVN, it has CRLFs and we have a similar svn property to force CRLF for bat files for svn.
The only thing I can think of why this is suddenly an issue is I think this might be the first commit I have made to these files since we added the git attributes for bat files.
So perhaps before it took the file literally and now (it does something weird like store it with LF for push it down with CRLF)
Any non-windows person seeing the same issue?
I thought internally that Git always stores files with some linebreak specific to server and it's when the user pulls it down, that it may change line breaks for select files based on rules, so should be ignoring these for cloning.  Like I always get files down with CRLF (even .sh files, .sql, and config files unless specific gitattribute rules are in place) which drove me nuts cause then they'd cause all sorts of compile errors and false regression errors when running under a Unix shell in windows.
Thanks,
Regina
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of John Harvey
Sent: Thursday, August 25, 2016 1:32 PM
To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
Subject: Re: [postgis-devel] Current master branch of postgis causing clone issues ?
Hi Regina,
Thanks for your reply.
Ok, I think I know the issue and can explain it.
I *believe* that the 2 batch files were actually committed with LF-only.
Here's how I'll try to prove it:
First, let's grab the raw file from *before* the Tiger 2016 commit:
git show 2a35bea:extras/tiger_geocoder/create_geocode.bat > ~/before_create_geocode.bat
That command may look weird, but I'm doing it this way to prevent any gitattribute changes or git config changes.
Second, let's grab the raw file *from* the Tiger 2016 commit
git show 598fea:extras/tiger_geocoder/create_geocode.bat > ~/after_create_geocode.bat
When I open ~/before_create_geocode.bat in a hex editor, I see that each line ends in "$0D0A", i.e. CRLF
However, when I open ~/after_create_geocode.bat, I see that each line now only ends in "$0A", i.e LF.  So, the CR was dropped in the last commit.  That's why in my environment (a mac, using git), the .gitattributes file starts "fixing" things to be "$0D0A".
I've also verified that my pull-request I've sent in does contain the right raw $0D0A endlines.
I know that it's an SVN project, so that may not be helpful-- I can try to produce a patch-file if possible (or whatever you need).
Regards,
  -John
On Thu, Aug 25, 2016 at 11:00 AM, Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > wrote:
John,
The .gitattributes ignore has been there for some time I think.  So that isn't new.
I did make commit to those two last batch files on 8/17.  Looking at the carriage return type they look like crlf to me.
Then again I'm on windows so things usually come down that way anyway unless explicitly set in gitattributes.
When I do a git clone and git status I get:
On branch svn-trunk
Your branch is up-to-date with 'origin/svn-trunk'.
nothing to commit, working directory clean
Perhaps someone not on windows can check and see if they are seeing the same thing.
It might be something introduced by the mirroring, because github is not our official repo.  We still use SVN so when I commit I commit on the svn repo and it gets mirrored to github.
Thanks,
Regina
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org <mailto:postgis-devel-bounces at lists.osgeo.org> ] On Behalf Of John Harvey
Sent: Thursday, August 25, 2016 10:19 AM
To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org <mailto:postgis-devel at lists.osgeo.org> >
Subject: [postgis-devel] Current master branch of postgis causing clone issues ?
Hello all,
I see something weird in PostGIS at the moment.
When I do:
mkdir ~/git
cd ~/git
git clone git at github.com:postgis/postgis.git <mailto:git at github.com:postgis/postgis.git>
cd postgis
git status
I notice the following:
            modified:   extras/tiger_geocoder/create_geocode.bat
            modified:   extras/tiger_geocoder/upgrade_geocoder.bat
Although, I didn't modify these files.  I just did a regular clone.
I suspect the .gitattributes file has something to do with it.
The 2 files impacted are Windows files, so probably have the wrong carriage-return type.
And, in the .gitattributes file, I see this rule:
*.bat       eol=crlf
So, I think this forces a change after clone.
I suspect this problem was introduced in the latest commit from 8/17 (it seems the endline changes were committed there).
Does anyone else see this problem?  Is this something that can be fixed?
Thanks!
  -John Harvey
postgis-devel mailing list
http://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20160825/00979154/attachment.html>
