[postgis-devel] Current master branch of postgis causing clone issues ?
John Harvey john.harvey at crunchydata.com
Fri Aug 26 07:55:09 PDT 2016
Hello Regina,
I thought about what you said, and decided to do some validation.
I am now confident that you are correct-- that it's an "svn sync to git"
issue.
Your commit for Tiger Encoding 2016 in svn definitely is CRLF in
subversion, but LF on the git side only.
So, it looks like something gets lost on the sync.
I had a thought, and looked back in the history-- this issue seems to have
happened once before.
The last Tiger Encoder updates (from 2015) were committed about last year,
under svn commit 13906.
Afterward, strk made the follow-up svn commit 13909 that had comment
"Commit the file with crlf as requested by .gitattribute (I think)".
When I inspect both of these commits, it's confusing-- I see that they both
are using CRLF on the subversion side.
So, it looks like strk did some magic that I cannot understand.  I'm
thinking that we'll need that magic once more.
Regards,
  -John
On Thu, Aug 25, 2016 at 3:33 PM, Regina Obe <lr at pcorp.us> wrote:
> I'm thinking it's still the git mirroring that converted  CRLF to LF.  So
> might be something strk needs to look into since he's in charge of the
> mirroring to github.
> Looking at the file locally that I committed to SVN, it has CRLFs and we
> have a similar svn property to force CRLF for bat files for svn.
> The only thing I can think of why this is suddenly an issue is I think
> this might be the first commit I have made to these files since we added
> the git attributes for bat files.
> So perhaps before it took the file literally and now (it does something
> weird like store it with LF for push it down with CRLF)
> Any non-windows person seeing the same issue?
> I thought internally that Git always stores files with some linebreak
> specific to server and it's when the user pulls it down, that it may change
> line breaks for select files based on rules, so should be ignoring these
> for cloning.  Like I always get files down with CRLF (even .sh files, .sql,
> and config files unless specific gitattribute rules are in place) which
> drove me nuts cause then they'd cause all sorts of compile errors and false
> regression errors when running under a Unix shell in windows.
> Thanks,
> Regina
> *From:* postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] *On
> Behalf Of *John Harvey
> *Sent:* Thursday, August 25, 2016 1:32 PM
> *To:* PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
> *Subject:* Re: [postgis-devel] Current master branch of postgis causing
> clone issues ?
> Hi Regina,
> Thanks for your reply.
> Ok, I think I know the issue and can explain it.
> I *believe* that the 2 batch files were actually committed with LF-only.
> Here's how I'll try to prove it:
> First, let's grab the raw file from *before* the Tiger 2016 commit:
> git show 2a35bea:extras/tiger_geocoder/create_geocode.bat >
> ~/before_create_geocode.bat
> That command may look weird, but I'm doing it this way to prevent any
> gitattribute changes or git config changes.
> Second, let's grab the raw file *from* the Tiger 2016 commit
> git show 598fea:extras/tiger_geocoder/create_geocode.bat >
> ~/after_create_geocode.bat
> When I open ~/before_create_geocode.bat in a hex editor, I see that each
> line ends in "$0D0A", i.e. CRLF
> However, when I open ~/after_create_geocode.bat, I see that each line now
> only ends in "$0A", i.e LF.  So, the CR was dropped in the last commit.
> That's why in my environment (a mac, using git), the .gitattributes file
> starts "fixing" things to be "$0D0A".
> I've also verified that my pull-request I've sent in does contain the
> right raw $0D0A endlines.
> I know that it's an SVN project, so that may not be helpful-- I can try to
> produce a patch-file if possible (or whatever you need).
> Regards,
>   -John
> On Thu, Aug 25, 2016 at 11:00 AM, Regina Obe <lr at pcorp.us> wrote:
> John,
> The .gitattributes ignore has been there for some time I think.  So that
> isn't new.
> I did make commit to those two last batch files on 8/17.  Looking at the
> carriage return type they look like crlf to me.
> Then again I'm on windows so things usually come down that way anyway
> unless explicitly set in gitattributes.
> When I do a git clone and git status I get:
> On branch svn-trunk
> Your branch is up-to-date with 'origin/svn-trunk'.
> nothing to commit, working directory clean
> Perhaps someone not on windows can check and see if they are seeing the
> same thing.
> It might be something introduced by the mirroring, because github is not
> our official repo.  We still use SVN so when I commit I commit on the svn
> repo and it gets mirrored to github.
> Thanks,
> Regina
> *Sent:* Thursday, August 25, 2016 10:19 AM
> *Subject:* [postgis-devel] Current master branch of postgis causing clone
> issues ?
> Hello all,
> I see something weird in PostGIS at the moment.
> When I do:
> mkdir ~/git
> cd ~/git
> git clone git at github.com:postgis/postgis.git
> cd postgis
> git status
> I notice the following:
>             modified:   extras/tiger_geocoder/create_geocode.bat
>             modified:   extras/tiger_geocoder/upgrade_geocoder.bat
> Although, I didn't modify these files.  I just did a regular clone.
> I suspect the .gitattributes file has something to do with it.
> The 2 files impacted are Windows files, so probably have the wrong
> carriage-return type.
> And, in the .gitattributes file, I see this rule:
> *.bat       eol=crlf
> So, I think this forces a change after clone.
> I suspect this problem was introduced in the latest commit from 8/17 (it
> seems the endline changes were committed there).
> Does anyone else see this problem?  Is this something that can be fixed?
> Thanks!
>   -John Harvey
> postgis-devel mailing list
> http://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20160826/3520a430/attachment.html>
