[postgis-devel] utils/check_all_upgrades.sh
Sandro Santilli strk at kbt.io
Fri Oct 7 13:10:07 PDT 2016
I've enabled automated upgrades testing in Dronie (see .drone.yml)
The automated testing revealed a bug in aggregate upgrades which
was pending since 2.2.0 times [1]. I've fixed it in 2.3 and trunk
branches, but note that upgrading from 2.3.0 to 2.3.1 won't fix
the existing databases, as our upgrade logic only applies between
minor (not micro) releases.
[1] https://trac.osgeo.org/postgis/ticket/3656
If you want to help with testing more upgrade paths, it would
be a matter of installing more postgis versions in the build-test
docker [2]. Want to help there ?
[2] https://git.osgeo.org/gogs/postgis/postgis-docker
--strk;
On Fri, Oct 07, 2016 at 05:46:55PM +0200, Sandro Santilli wrote:
> I've committed a utils/check_all_upgrades.sh script that would
> run "make check" with --extension and --upgrade-path for each
> available upgrade to a given target version.
> My local tests see most upgrade checks failing due to a WARNING
> about postgis_backend being redefined, anyway it's a start.
> I guess we should also be using perl instead of shell, if you feel
> like porting it.
> If we get to fix the upgrade checks, we could add upgrade paths
> via the Dronie build-test docker to add another important aspect
> of testing. Want to help ?
> --strk;
>   ()   Free GIS & Flash consultant/developer
>   /\   https://strk.kbt.io/services.html
