[postgis-devel] Docs broken for other languages
Sandro Santilli strk at kbt.io
Fri Jan 27 22:59:44 PST 2017
On Fri, Jan 27, 2017 at 06:03:51PM -0500, Regina Obe wrote:
> Did we ever setup Debbie to automatically pull from transifex.  I think I had installed the client and that you might have had something in shell scripts to pull the file, but can't remember.
make -C doc pull-tx
But I'm not sure we want bots to do that automatically as after confirming
the translations work (make -C doc html-localized pdf-localized) the pulled
changes should be committed to the repository.
--strk;
