[postgis-devel] Docs broken for other languages
Regina Obe lr at pcorp.us
Sun Jan 29 12:11:04 PST 2017
> On Fri, Jan 27, 2017 at 06:03:51PM -0500, Regina Obe wrote:
>> Did we ever setup Debbie to automatically pull from transifex.  I think I had installed the client and that you might have had something in shell scripts to pull the file, but can't remember.
> make -C doc pull-tx
> But I'm not sure we want bots to do that automatically as after confirming the translations work (make -C doc html-localized pdf-localized) the pulled changes should be committed to the repository.
> --strk;
Agreed. How about you do that?  Ideally I'd like the 2.3  and 2.4 docs up to date before I do the 2.3.2 release in a couple of days.
I think I can at least build some of them without issue like all the latin based languages.
