[postgis-devel] Docs broken for other languages
Sandro Santilli strk at kbt.io
Tue Jan 31 11:18:53 PST 2017
On Tue, Jan 31, 2017 at 04:02:19PM -0200, George Silva wrote:
> george at winterfell ~/projetos/postgis/doc $ make html-localized
> make: *** No rule to make target 'html-localized'.  Stop.
> george at winterfell ~/projetos/postgis/doc $ make pull-tx
> make: *** No rule to make target 'pull-tx'.  Stop.
Did you run ./configure from the top-level dir ?
You'd get that message in absence of a Makefile
(which is generated by ./configure from Makefile.in)
> I'm a little green with makefiles :D
First step is *having* a Makefile, see if you can get there :)
--strk;
