[postgis-devel] topology pgsql 10 regression failures
Regina Obe lr at pcorp.us
Fri May 26 11:05:16 PDT 2017
Hmm mysteriously it's not failing on my PostgreSQL 10 anymore either.  So guess it wasn't what I thought it was.
I guess I'll just close that out unless it happens again.  Don't know what changed betwee the two revisions.
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
Sent: Friday, May 26, 2017 1:43 PM
To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
Subject: Re: [postgis-devel] topology pgsql 10 regression failures
Look at the test that is failing, it has nothing to do w/ selectivity:
-- #3399
WITH g as (
select 'POLYGON((1 0, 0 1, 1 2, 2 1, 1 0))'::geometry as geom
n as (
select n from unnest(ARRAY[-1,0,1,10,100,1000]) n
pts as (
  select n,(st_dump(st_generatepoints(geom, n))).geom from g,n
select '#3399' as t, n, count(*) from
g, pts
where st_contains(g.geom, pts.geom)
group by n
ORDER BY n;
(Incidentally, works fine on OSX)
P
On Fri, May 26, 2017 at 10:35 AM, Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > wrote:
I beat you to it :)
https://trac.osgeo.org/postgis/ticket/3764
I'll try to fix when I get the chance.
BTW: For this error, are you seeing this one?
https://trac.osgeo.org/postgis/ticket/3759
/tmp/2.4.0dev_pg10_geos3.7.0dev_gdal2.1.3w64/test_89_diff)
--- tickets_expected   2016-09-26 01:59:38 -0400
+++ /projects/postgis/tmp/2.4.0dev_pg10_geos3.7.0dev_gdal2.1.3w64/test_89_out        2017-05-25 15:15:09 -0400
@@ -285,7 +285,7 @@
#3375|GEOMETRYCOLLECTION(POINT(0 -7))
#3399|1|1
#3399|10|10
-#3399|100|100
+#3399|100|99
#3399|1000|1000
ERROR:  invalid KML representation
#3437a|5
Do we go with float or float4.  If float4, I think you need to change the regression and also the pre-10 code.
the geometry regression in tickets caused by this change
 nd_stats = palloc(sizeof(float) * sslot.nnumbers);
 memcpy(nd_stats, sslot.numbers, sizeof(float) * sslot.nnumbers);
To:
 nd_stats = palloc(sizeof(float4) * sslot.nnumbers);
 memcpy(nd_stats, sslot.numbers, sizeof(float4) * sslot.nnumbers);
Thanks,
Regina
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org <mailto:postgis-devel-bounces at lists.osgeo.org> ] On Behalf Of Paul Ramsey
Sent: Friday, May 26, 2017 11:13 AM
To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org <mailto:postgis-devel at lists.osgeo.org> >
Subject: [postgis-devel] topology pgsql 10 regression failures
Several failures for me (Darwin Kernel Version 15.6.0) right now in topology, for example,
regress/st_simplify .. failed (diff expected obtained: /tmp/pgis_reg/test_26_diff)
This "invalid geometry type" shows up in a few of the other failures further down. Anyone seeing similar things w/ pgsql 10?
--- regress/st_simplify_expected    2014-12-01 12:28:41.000000000 -0800
+++ /tmp/pgis_reg/test_26_out   2017-05-26 08:02:22.000000000 -0700
@@ -1,9 +1,8 @@
 t
 L1
-N2
-S1|f|t
-S2|f|t
+ERROR:  Invalid geometry type (POLYGON) passed to TopoGeo_AddLinestring, expected LINESTRING
+N1
+S1|f|
+S2|f|
 L2
-HS1|f|t
-HS2|f|t
 f
postgis-devel mailing list
https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20170526/f9a4866d/attachment.html>
