[postgis-devel] topology pgsql 10 regression failures
Paul Ramsey pramsey at cleverelephant.ca
Fri May 26 10:42:53 PDT 2017
Look at the test that is failing, it has nothing to do w/ selectivity:
-- #3399
WITH g as (
select 'POLYGON((1 0, 0 1, 1 2, 2 1, 1 0))'::geometry as geom
n as (
select n from unnest(ARRAY[-1,0,1,10,100,1000]) n
pts as (
  select n,(st_dump(st_generatepoints(geom, n))).geom from g,n
select '#3399' as t, n, count(*) from
g, pts
where st_contains(g.geom, pts.geom)
group by n
ORDER BY n;
(Incidentally, works fine on OSX)
P
On Fri, May 26, 2017 at 10:35 AM, Regina Obe <lr at pcorp.us> wrote:
> I beat you to it J
> https://trac.osgeo.org/postgis/ticket/3764
> I'll try to fix when I get the chance.
> BTW: For this error, are you seeing this one?
> https://trac.osgeo.org/postgis/ticket/3759
> /tmp/2.4.0dev_pg10_geos3.7.0dev_gdal2.1.3w64/test_89_diff)
> --- tickets_expected   2016-09-26 01:59:38 -0400
> +++ /projects/postgis/tmp/2.4.0dev_pg10_geos3.7.0dev_gdal2.1.3w64/test_89_out
> 2017-05-25 15:15:09 -0400
> @@ -285,7 +285,7 @@
> #3375|GEOMETRYCOLLECTION(POINT(0 -7))
> #3399|1|1
> #3399|10|10
> -#3399|100|100
> +#3399|100|99
> #3399|1000|1000
> ERROR:  invalid KML representation
> #3437a|5
> Do we go with float or float4.  If float4, I think you need to change the
> regression and also the pre-10 code.
> the geometry regression in tickets caused by this change
>  nd_stats = palloc(sizeof(float) * sslot.nnumbers);
>  memcpy(nd_stats, sslot.numbers, sizeof(float) * sslot.nnumbers);
> To:
>  nd_stats = palloc(sizeof(float4) * sslot.nnumbers);
>  memcpy(nd_stats, sslot.numbers, sizeof(float4) * sslot.nnumbers);
> Thanks,
> Regina
> *From:* postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] *On
> Behalf Of *Paul Ramsey
> *Sent:* Friday, May 26, 2017 11:13 AM
> *To:* PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
> *Subject:* [postgis-devel] topology pgsql 10 regression failures
> Several failures for me (Darwin Kernel Version 15.6.0) right now in
> topology, for example,
> regress/st_simplify .. failed (diff expected obtained:
> /tmp/pgis_reg/test_26_diff)
> This "invalid geometry type" shows up in a few of the other failures
> further down. Anyone seeing similar things w/ pgsql 10?
> --- regress/st_simplify_expected    2014-12-01 12:28:41.000000000 -0800
> +++ /tmp/pgis_reg/test_26_out   2017-05-26 08:02:22.000000000 -0700
> @@ -1,9 +1,8 @@
>  t
>  L1
> -N2
> -S1|f|t
> -S2|f|t
> +ERROR:  Invalid geometry type (POLYGON) passed to TopoGeo_AddLinestring,
> expected LINESTRING
> +N1
> +S1|f|
> +S2|f|
>  L2
> -HS1|f|t
> -HS2|f|t
>  f
> postgis-devel mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20170526/549c311c/attachment.html>
