[postgis-devel] Testing pgRouting
Vicky Vergara vicky at georepublic.de
Fri Nov 3 09:11:59 PDT 2017
​Hi all,
I used to be able to  test pgRouting ​using changing the postgis version to
the latest version you rleased on AppVeyor testing CI.
But I am stuck now on version 2.3.3
Versions greater than that one give me this kind of error: (the 2.4 is
because I tried to use postgis 2.4.1)
ERROR: could not load library "C:/Program
Files/PostgreSQL/9.4/lib/rtpostgis-2.4.dll": %1 is not a valid Win32
application.
Like in the execution test on [1] line 1603
The files involved for the AppVeyor tests are [2] & [3]
Maybe you can give me a hand.
Thanks
Vicky
[1] https://ci.appveyor.com/project/cvvergara/pgrouting/build/2.5.1890
[2] https://github.com/pgRouting/pgrouting/blob/master/appveyor.yml
[3]
https://github.com/pgRouting/pgrouting/blob/master/ci/appveyor/install.bat
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, Germany
Vicky Vergara
Operations Research
eMail: vicky at georepublic.de
Web: https://georepublic.info
Tel: +49 (089) 4161 7698-1
Fax: +49 (089) 4161 7698-9
Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20171103/955edb13/attachment.html>
