[postgis-devel] ST_Segmentize geography go back to old 2.2 behavior
Mike Toews mwtoews at gmail.com
Sat Sep 23 21:01:56 PDT 2017
On 23 September 2017 at 02:22, Regina Obe <lr at pcorp.us> wrote:
> I like that idea except that would require proj 4.9 or above which is not required at least for 2.4.
> I'm okay with living with this bug for 2.4, and maybe in PostGIS 2.5 we rewrite it and make Proj 4.9 a minimum requirement.
There's already a PROJ_GEODESIC define used to compile code on Proj
4.9 support. So Proj 4.9 doesn't necessarily need to be a minimum
requirement. With PROJ_GEODESIC would use new (and unwritten) code,
and without would use 2.2 or 2.3 behavior.
You can also see PROJ_GEODESIC in liblwgeom/cunit/cu_geodetic.c to
test results depending on the Proj library.
Cheers, Mike
