[postgis-devel] postgis 2.4.3 (and 2.3.6) release?
Regina Obe
lr at pcorp.us
Fri Jan 12 13:39:26 PST 2018
Strk, dustymugs
You two okay with a release say this weekend.
I might be a bit busy this weekend but I'll try to get to it at least clean up all the loose ends so not much to cleanup next week.
Paul said he can't do this weekend but can probably release Monday if I haven't already released.
Packagers -- do you all need a longer than a day's heads up for a release notice? Let us know, I suppose we could push another week if needed.
Thanks,
Regina
-----Original Message-----
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
Sent: Friday, January 12, 2018 8:55 AM
To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
Subject: Re: [postgis-devel] postgis 2.4.3 (and 2.3.6) release?
Backported the ST_Transform fix into 2.3 and 2.4.
I'm OK w/ patch releases.
P
On Fri, Jan 12, 2018 at 1:11 AM, Sandro Santilli <strk at kbt.io> wrote:
> On Fri, Jan 12, 2018 at 12:52:08AM -0500, Regina Obe wrote:
>> Paul and Sandro,
>> Did you want to get the fix in for the ST_Transform schema qualification before we do the next release?
>> I would think that would be the only reason to hold up a release any longer.
> It looks like Paul nailed that already (but needs to be backported
> still ?)
> Rather, did we break pg_upgrade with that BRIN upgrade fix ?
> Or are we already recommending to upgrade postgis right after a
> pg_upgrade and thus are happy about it ?
> --strk;
> postgis-devel mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
