[postgis-devel] [postgis-users] PostGIS 2.5.0 alpha released
Greg Troxel gdt at lexort.com
Wed May 30 11:29:45 PDT 2018
Continuing along, I am looking at the diff in the "PLIST", which is
pkgsrc's manifest of files.  Of course things change, but part of the
benefit is seeing if all the changes make sense.  Most of the following
seems fine, but the last line is puzzling, as if we are no longer
installing sql for the tiger geocoder, but still have upgrade sql.  But
maybe the --${PKGVERSION}.sql line is the proper install, and there was
a spurious installation before, and it got fixed.
There is also the new "ANY" line which seems a bit funny.
@@ -116,13 +118,14 @@ share/postgresql/extension/postgis_tiger
 share/postgresql/extension/postgis_tiger_geocoder--2.4.1--${PKGVERSION}.sql
 share/postgresql/extension/postgis_tiger_geocoder--2.4.2--${PKGVERSION}.sql
 share/postgresql/extension/postgis_tiger_geocoder--2.4.3--${PKGVERSION}.sql
+share/postgresql/extension/postgis_tiger_geocoder--2.4.4--${PKGVERSION}.sql
+share/postgresql/extension/postgis_tiger_geocoder--2.4.5dev--${PKGVERSION}.sql
 share/postgresql/extension/postgis_tiger_geocoder--${PKGVERSION}--${PKGVERSION}next.sql
 share/postgresql/extension/postgis_tiger_geocoder--${PKGVERSION}.sql
-share/postgresql/extension/postgis_tiger_geocoder--${PKGVERSION}dev--${PKGVERSION}.sql
 share/postgresql/extension/postgis_tiger_geocoder--${PKGVERSION}next--${PKGVERSION}.sql
+share/postgresql/extension/postgis_tiger_geocoder--ANY--${PKGVERSION}.sql
 share/postgresql/extension/postgis_tiger_geocoder--unpackaged--${PKGVERSION}.sql
 share/postgresql/extension/postgis_tiger_geocoder.control
-share/postgresql/extension/postgis_tiger_geocoder.sql
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20180530/5a55bdda/attachment.sig>
