[postgis-devel] [postgis-users] PostGIS 2.5.0 alpha released
Greg Troxel gdt at lexort.com
Wed May 30 11:52:49 PDT 2018
"Regina Obe" <lr at pcorp.us> writes:
> Hmm I've been seeing errors too (haven't checked if they match yours) but
> chucked it up to an upgrade in ImageMagick on debbie and that we need to
> revise our image magick rendering script.
> When I looked at the generated html and pdfs, they didn't seem to be
> affected by these errors so I kinda ignored them since more pressing things
> to attend to.
> Did the images build okay for you e.g. the images/de9im02.png ?
That looks like an intended image.
> The image magick routine builds the images from .wkt files (that contain
> lines of well-known geometries ) using our liblwgeom lib.
> The generator was last changed Jan 2018 and the change was not backported to
> 2.4, so I guess that might have caused this issue.
> https://trac.osgeo.org/postgis/changeset/16296
> I have ticketed at https://trac.osgeo.org/postgis/ticket/4098
I hope that building before/after that change makes things clear...
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20180530/56fce4a1/attachment.sig>
