[postgis-tickets] [PostGIS] #2269: Unreasonable memory usage when analyzing table with geometry column with many toasted datums
PostGIS trac at osgeo.org
Tue Apr 9 19:51:46 PDT 2013
many toasted datums
  Reporter:  pgeoghegan  |       Owner:  strk
      Type:  defect      |      Status:  reopened
  Priority:  blocker     |   Milestone:  PostGIS 2.0.4
 Component:  postgis     |     Version:  2.0.x
Resolution:              |    Keywords:  toast,leak
Comment(by robe):
 trunk wasn't blowing just because we don't support 8.4 on PostGIS 2.1 and
 the crash only seemed to happen on the 8.4 regress.  I haven't tested
 locally on my 8.4 32-bit.  Winnie doesn't test 8.4 because there is no
 64-bit support for 8.4 and I can't compile 8.4 with mingw64 chain.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2269#comment:13>
