[postgis-tickets] [PostGIS] #2269: Unreasonable memory usage when analyzing table with geometry column with many toasted datums
PostGIS trac at osgeo.org
Tue Apr 9 20:01:37 PDT 2013
many toasted datums
  Reporter:  pgeoghegan  |       Owner:  strk
      Type:  defect      |      Status:  reopened
  Priority:  blocker     |   Milestone:  PostGIS 2.0.4
 Component:  postgis     |     Version:  2.0.x
Resolution:              |    Keywords:  toast,leak
Comment(by robe):
 I'll keep this open for now because winnie is totally blowing crashes on
 install of postgis after this change.  Might be unrelated since I was
 upgrading pg micros on her too and I'll test on my local instances as
 well.
 At least your last change seems to make debbie 8.4 regress pass now.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2269#comment:14>
